Hi guys,
new to the forum and watercooling!
Just built my first water cooled rig, pretty impressed with myself to be honest! Didn't think it would come out as clean as it did! Only made 1 mistake with PETG tubing too.
So I installed everything and started to fill the Corsair XD5 pump/res combo and the pump was perfectly quiet and then boom I'm getting some strange crackling, vibrating kind of noise coming from the pump.
I assumed it was air (I didn't run the pump dry) and carried on with leak testing and even booted up perfectly fine. Bios showed pump running at 100% even though 4 pin connector is connecting to the water pump header.
I've tilted the whole rig in all directions possible to remove air. There is no air in the tubes and possible a small amount of air in the rads (not 100% sure). But this noise is a little concerning.
Build details - watercooling side (if needed):
https://imgur.com/DDpbn38
When it was running the temps were great - even gamed shortly just to make sure things were seated correctly.
All components were brand new from Overclockers apart from the GPU block.
Any advice would be much appreciated.
- EK SE coolstream slim classic 360 with Noctua NF-F12 (using these off my 360 ryujin)
- EK PE coolstream 360 with Noctua NF-F12 3000rpm
- EK Velocity CPU Block
- EK Vector RTX RE GPU block
- EK 10/12mm PETG tubing
- All EK fittings apart from the Y splitter and the 90's.
- EK Cryofuel coolant with EK Indigo Violet concentrate.
- Corsair XD5 pump/res combo.
