10850K OC settings check
29 May 2021
Denmark
Hello everyone.
Im new here, but i just got an 10850K and is in progress of overclocking it a bit
can someone tell me if these settings are good or bad?
First specs.
10850K
Asus Z490 Gaming-F
LPX 3600Mhz CL18 1.35V
Current bios settings
Core ratio - 51
AVX - 0
Set Vcore 1.320V (Fixed)
LLC - 6
MCE - Enabled - remove all limits
Vccio and Vccsa - Both 1.15v
CPU SVID Support - Disabled
BCLK Aware Adaptive Voltage - Disabled
Cpu Current Capability - 170%
Cpu core/cache current limit - Maxed
Long duration/Short Duration - Maxed
Package power time window - Maxed
Cpuz and HWinfo
Vcore idle - 1.314V
Vcore Load - 1-305-1.314V
70-75 Degree celsius
have not had a crash with these settings, but im not really sure about the LLC, i so confused on that topic, does not seem to understand the LLC nomatter how much im reading or watch explanation videos about it.
so i would be very pleased if someone could tell me if the settings are any good :)
LLC stops the voltage dipping to much at load as that can cause instability, you want some dip though else you will get higher spikes if you use to much load line and these can push high voltage through the CPU momentary which will ultimately degrade the chip faster.
so what do you suggest i change in the settings? :)
Just dropped LLC to 5 crashed Cinebench, but i soft crash, just got an error messege and cinebench closed.
Bumped Voltage from 1.320V to 1.325V
passed Cinebench again now
Cpuz shows 1.323V Idle
And 1.279V on load now
i will do some more stress testing to see if its 100% stable again on LLC 5 with the little voltage bump if the settings seems alittle better now
