Permabanned
- 4 Sep 2011
- Durham
I don’t know if I’m missing something obvious here so any help would be great.
My TUF 3090 keeps throttling down to as low as 1590mhz when under 100% load. I’ve undervolted it down to 885mv and set a max of 1935mhz. Card tops out at 70 degrees at 70% fan speed. Power limit I’ve left at 100%. Where’s my issue here? Could it be the thermal pads I’ve read about? Being honest, if thats the case I’m not really confident of replacing them.
Case is the Corsair 5000x and air flow isn’t an issue. Top rad AIO so cool air coming in the front.
Last two games I’ve been playing that I’ve noticed it in mostly have been Resident evil village and Gears 5. At 4K these are around 80fps most of the time so I’m not running up against a frame limiter or anything like that but Cyberpunk seemed to run around 1900mhz most of the time fully maxed despite much lower frames.
