Good.
There should be no reason to disable SAM for AMD systems (looking at you Hardware Unboxed) as it's a free performance lift in most games and as you can see, it puts the 6900 XT level with the 3090 at 4K and ahead at resolutions below - whilst drawing less power.
I don't think they are biased to either vendor, but there is no valid reason not to enable SAM IMO.Its quite surprising the `editorial` direction Hardware Unboxed has taken recently , heading back to the same camp that JayZ occupies....
Gotta admit, still havent bothered with re-size bar on my 3090, has it improved in any way? AMD seems way ahead of the curve this time, props to them.
Nothing but problems after bios-vbios-geforce driver updates for resize bar. It's resized my PC into a piece of sh*te![]()
I've certainly had no issues with resize bar fully enabled with my 3090 since I flashed the VBIOS in March. No weird game issues, no system issues and games have been running just fine.
GPU-Z 2.4.0 has added Re-Size bar information which is very helpful
Thanks that's helpful, just checked and turned out Resize BAR wasn't active. I was like "WTF, I'm sure I flashed the vBIOS and enabled above 4G decoding / resize BAR the other day?!?".
Checked BIOS, and yep, both enabled/Auto.
Quick google and I found people saying you needed to disable CSM (Compatibility Support Module). Disabled that, and now it's working.
