- 30 Jul 2012
No, they are exclusive to another store, they will not appear until the drop time.Do OcUK sell FEs?
Talking about like for like models. So amp should be same as amp.So the twin edges will be trinity models - the holos keeping the same name, but with 3 smaller fans?
OK, just to be clear - only the amp holos will stay the same dimension?Talking about like for like models. So amp should be same as amp.
I'm assuming all models should be identical to their old counter parts. Only way to be 100% sure would be to wait for release.OK, just to be clear - only the amp holos will stay the same dimension?
OK thanks.I'm assuming all models should be identical to their old counter parts. Only way to be 100% sure would be to wait for release.
You'll see the prices on mobile browser.
I reckon the USD figure is similar to GBP on release.
3070Ti would be £599
3080Ti would be £1199
x infinityYeah.The 3080ti FE releases tomorrow 3rd June and 3070ti FE 10th June, that correct?
Would you like fries with that? It may only last a few minutes but I'm sure someone will.If an AIB version of either of those GPUs are available for those prices I'll eat my virtual hat.
Ah great, so I'll not need to be keeping an eye out tomorrow! CheersYeah.
I wouldn't know if or if not retailers will do pre-orders, some place have already listed 3070 Ti's.Ah great, so I'll not need to be keeping an eye out tomorrow! Cheers
Very good point - though presumably an FE is either for sale or not, rather than pre-orderable?I wouldn't know if or if not retailers will do pre-orders, some place have already listed 3070 Ti's.
Worth checking I guess, but probably won't be.Very good point - though presumably an FE is either for sale or not, rather than pre-orderable?
I'm only even considering a 'new' card because the MM prices for previous generation cards have gone daft and I just can't justify old cards for more than the newer ones! But that's me as someone who isn't too fussed if I have to carry on with my 980ti. I understand others wanting to upgrade sooner.
