Anyone have perfect fit blinds?
18 Oct 2002
Kent
I have a large bedroom window (175cm x 118cm) and i'd really like to have a perfect fit blackout blind for it. The trouble i'm having is that most of the blinds companies dont do them for windows wider than 140cm and the companies that send a person to your home to measure and install them offer no indication as to the cost.
I'm wondering if anyone here them and can tell me how much they cost?
Thanks
Permabanned
22 Jul 2020
There was thread last week or so ago, try there but none seem to be 100% with some light in some areas.
Go to the site and see how much.
27 May 2003
Rotate them 90 degrees so they open and close on the horizontal. You'll find ones that fit with those dimensions.
21 Jan 2010
I posted in the previous thread (+ in the man jobs thread). I went BlocBlinds. Proper 0 light blackout with the exception of two tiny holes left and right (by design I guess).
They do up to a max width of 2.4m. A quick quote on your sizes puts it at about £299.
23 Nov 2019
we have timber venetian blinds and then black out curtains over them. It's an excellent combination as the wood blinds let you control light, airflow, etc during the day, while still giving privacy, and a better view than net curtains. The curtains do the blackout job and add noise insulation at night. If you have a sewing machine ordering dense lining or full black-out lining is relatively easy and you can sew it onto the back of other curtains. It's a lot easier than trying to find nice blackout curtains to begin with.
OP
18 Oct 2002
Kent
Thanks for the help fellas.
I just had a look at their blackout blinds and this one came in at £189. Which one were you looking at that costs £299?
21 Jan 2010
Ah dreamy. I didn't realise the regular BlocBlinds did up to 180cm (I had clicked BlocBlinds XL). Maybe there is where the difference came from.
Edit: this is mine for what it's worth:
https://i.imgur.com/cqUUgR0.jpeg
Make sure you get your measurements spot on...
28 Nov 2002
Cumbria
I got mine inc fitting for just over £100 , window just a bit smaller than yours
Actually having re read your post I notice yours are wide , mine are tall , approx 1m x1.5m
do you need perfect fit? They are good but theyres better options if they’re essential
OP
18 Oct 2002
Kent
I'm very light sensitive so i'm looking at ways to keep my room as near to absolute darkness as possible.
28 Nov 2002
Cumbria
tbh I have found the perfect fit still let in some light around the edges , my old roller blackout blind and curtains over it were better
18 Oct 2002
Manchester
Getting some fitted to 3 windows on Tuesday, so will update to give my impressions. I'm keeping the venetians already installed, the blocblinds will fit in the recess still so should block most of the light.
17 Nov 2003
St Breward Cornwall
There may be a little light coming through! Got my verticals from blinds 2 go for 3 windows, very cheap, as long as you give accurate measurements they are spot on, not a diyer but capable of drilling afew holes.
Originally they weren't blackout but got some new slats on ebay 99p each
21 Jan 2003
I just recently bought and fitted a BlocBlind. I was really impressed, it didn't require any modification, and was easy to fit, I didn't bother with the supplied pin nails because it's more than secure enough with the adhesive tape and the two vertical rails supporting it.
