- 19 Nov 2020
Hi,
PC has been running fine with no issues for a few years now (spec below) with only change being the addition of M.2 boot drive over a year ago but no issues since, but suddenly last week it stopped powering on at all (no fans turn or anything) when the button is pressed.
Power is getting to the pc, and the idle led's on the gpu flicker when pressing the power button so it does appear it's "trying" to boot, but otherwise nothing at all happens. If i clear cmos, it then boots without any problems at all.
So far i've tried replacing the battery, and updating bios to no effect. Worth noting is that it will reboot fine so long as the power supply doesnt lose power from the wall, which happens every night as it's turned off at the wall.
My next port of call would be to replace the motherboard as the problem appears to be bios/cmos related, but i'd rather seek a second opinion before having to pay out for that.
R7 3800X
MSI B450 Tomahawk MAX
16GB (2x8) 3600Mhz Corsair LPX
Asus 1080TI Strix OC
Corsair RM Series RM 850 '80+ Gold' 850W Power Supply
WD Black 1TB SN750 M.2
WD 4TB Red Pro 7200rpm
R7 3800X
