Man of Honour
The A52 is running a much lower CPU?Seems like you're enjoying it then. It's really difficult for me to decide between the F3 and the A52 5G. The 5G has a better CPU, isn't running MIUI etc... Tough call
It's running a SD 750?The A52 might be, but the A52 5G isn't
The Poco F3 has a far better spec, I sent back my Samsung S21 Ultra to keep this phone and I'm still very glad I did, as I mentioned in another post above, nothing I've seen can beat this phone for the £299 I paidYou're right, it is. The website I was looking at comparing the 2 has the wrong CPU listed
I didn`t during the install buddy.Thank you for the tip/link to that app @TheFifeFlyer. Have you noticed any adverts during install? I have debloated (using kona's suggested list from the previous page) and think I have anything ad related turned off, or perhaps you can't disable it entirely.
Dropped my 3-year old Ulefone Power 3 mobile yesterday and cracked the screen! . . . did a few hours of research for a nice battery phone with good screen for gaming, video watching and flicking through financial charts.
Xiaomi have a "Colourful Flowers" promotion running (31st May-6th June), last night was 6GB X3 Pro for £219 which I missed so now just comparing the three models above, leaning towards X3 Pro as original budget was £200 but you know how it is with a budget when you start comparing "just an extra £50" and before you know it you are convinced that your original £200 budget is weak and the extra spending justification begins!
- £229 - Poco X3 Pro 6GB+256GB
- £249 - Redmi Note 10 Pro 6GB+128GB (
£269)
- £349 - Poco F3 5G 8GB+256GB
Hi CAT-THE-FIFTH, thanks for those links, reading now!I would check the notebookcheck reviews, as they seem to be the only one who actually tests if the phones have sufficient cooling, and test GPS accuracy:
Oh wow look at that!
Have you had time to evaluate those models yet? I'm trying to put an order in today so anything you can add would be great.
https://www.gsmarena.com/compare.php3?idPhone1=10662&idPhone2=10802&idPhone3=10758
Ok, after some reading and watching YouTube reviews I've purchased a replacement for my cracked screen UleFone Power 3.
I went with a Xiaomi POCO X3 Pro 8GB/256GB for £199.49 inc with a handy PROMOFIVE discount code at auction. I didn't get an AMOLED screen but I did get a 7nm Snapdragon 860/Adreno 640 and 256GB of fast UFS 3.1 storage.
That's a nice upgrade for £200 smackers. Thanks for the feedback, good luck in your search!
The Poco X3 Pro heats up noticeably during use and reached up to 40.5 °C (~105 °F) in the test. Without the internal throttling, we would probably measure even higher surface temperatures under load. As the GFXBench battery tests show, the SoC performance remains practically constant in the graphically simple T-Rex scenario, but it drops right from the start in the more demanding Manhattan test.
What's your guys experience with MIUI? Seen lots of negative things about it online
2 yrs and done
