Caporegime
- 1 Dec 2010
- Welling, London
Shortest roll of honour ever
Yes I'd read about that on forums, its just a bit worrying when its your own PC.That's normal with GDDR6X I'm afraid. As long as you stay under 110C you're fine.
105C according to the new info micron added.That's normal with GDDR6X I'm afraid. As long as you stay under 110C you're fine.
https://www.micron.com/products/ultra-bandwidth-solutions/gddr6x
Here's mine! And yes that's an NZXT H1. Temps are actually better than my 5700xt.
They probably should have just used better thermal pads then it wouldn't need to run above spec.I hadn't seen that yet, cheers. Though on the Nvidia cards it doesn't throttle until 110C and speculation has it that Nvidia got special dispensation to run it above the official specs. Either way it's damn toasty.
Snug.Here's mine! And yes that's an NZXT H1. Temps are actually better than my 5700xt.
I wasnt even aware the 3080Ti had been released. On the roll of honour there are 3 cards. Is this the total Nvidia made?
Set up my TUF 3080 Ti yesterday. Got super lucky to get a card although didn't get too lucky with coil whine. Very noticeable compared to my 5700xt even at low frames. Currently playing with undervolting and moving my case to try and dampen the sound; definitely not sending it back in the current climate!
Really happy with the temps though, the TUF design is pretty good there.
