It should be in the 'Boot' section of your BIOS.I didn't disable CSM, only flashed the firmware of the GPU, turned it on in the motherboard bios and it's showing as active in Nvidia Control Panel.
Where is CSM?
Where is CSM?
Yah, turns out it was already off.
I haven't really seen a big improvement of fps with resizable bar on, seems like a gimmick?
Have you played a game that supports it?
There is only a handful that support it and the performance uplift is usually single digit percent so you're unlikely to notice much outside of benchmarking. it is kind of a gimmick for now but at the end of the day it's free performance for a few minutes of your time so can't complain
I agree. The game with biggest difference is Assassin's Creed Valhalla and that's still only 3-10 FPS extra at most at 1440P on my 3080, depending on the scene. AMD's version, called SAM, gets twice the improvement in this game and is generally a better implementation. You can see why AMD built their cards with it in mind whereas Nvidia enabled it last minute behind 'only enthusiasts need apply' hoops in response to AMD.Yah, turns out it was already off.
It's only enabled in 17 games on Nvidia so far which is why 3DMark showed no improvement (even if it were enabled I doubt it would show an improvement as only certain games benefit). RDR 2 is one of the games that's supposed to benefit so you should have seen some improvement.Played Rdr2 with it and couldn't really notice a difference , 3d Mark also did not show a good gain.
But hopeful that it'd still being developed. But it's not worth an upgrade in my opinion.
AMD enables it globally but I believe they have a blacklist of games with big performance regressions.
Well Nvidia claimed they were doing that but reviewers showed there were still regressions so it must be more difficult than you'd expectRDR 2, I'll play again , but fps is already high so it's usually in Saint Denis at night, the fps drops to 55fps and I didn't really see much but I'll check again.
Performance regression is not good, could they not just disable it for games that don't support it?
Looks like FE cards are now shipping with the updated firmware for resizable BAR. Still need motherboard BIOS support of course.
weirdly i never noticed any negative effects on a freaking b450 and 2700x with the 3070i would expect this combo to be most problematic yet i see nothing bu improvement, even in rainbow 6, where i enabled it via nvidia inspector and gained a proveable %2-3 boost
I got a 3080 FE about a month ago, and that supported ReBAR out the box.
Enjoy the GPU, it's very good tbh, I was just posting what I observed from ReBar. It doesn't take away anything from the card.
