I just added up the numbers in the memory bar, it's 32,768, so that's perfect.
The only thing left to check is that CPU-Z is still reporting dual channel memory.
For extra completeness you could also run another memory test.
What I guess has happened. I think there is dirt / grease that's on either the motherboard or memory contacts. When you moved the DIMM's around the dirt has been dislodged.
When a computer is left running with DIMM slots empty, over time dirt can get deposited in those slots.
If you have memory issues in future, you need to clean both the gold contacts on the memory, and also spray the DIMM slots on the motherboard. The best stuff to use is Servisol Aero-Klene 50. When you clean the memory, you hold memory on it's side over paper, spray the top part of gold contacts and let fluid run down washing any dirt away. Then of course let anything dry for about 15 mins before refitting memory.
Other than this, think we can call this a success, and it looks like everything is working
