Mine works fine with re bar enabled in bios. Not had a single issue with my gen 4 riser cable. That post was from a while ago.
Ok thanks both. Due to the sheer size of the gpu I’m only able to install via a riser cable. Do you know of any 4.0 riser cables that are of a well known brand. Can’t find any apart from an unknown brand on Amazon. Thanks
I've used a LinkUp PCIE 4 riser cable with an RTX 3070 and it worked fine in PCIE 4 mode
with riser cables, resizeable BAR or smart memory access is not possible. i found out the hard way! PC won't boot if you enable Re-BAR and with riser cable attached
Hah, sorry, I didn't checkThat post is about 7 months old now.
