Hi there
With the help of the DON's we think, WE MIGHT have found a better solution than MM which is less restrictive.
If you look up in the graphics forum section you will a new "Graphics Cards - Forum Member Deals" section, if you can see it, post here, if you can't see it also post here.
You can go post in my thread there too.
Hopefully a lot more people can access it and if true I shall run a trial voucher deal in there next week and we shall see how it goes, leak the code though and were back to MM only deals.
Note from Feek.
The permissions on that sub forum ARE NOT WORKING PROPERLY. If you can’t see it, logging out, clearing your cache, changing browser etc will make no difference.
Note from Feek.
