OcUK don't appear to sell Beyerdynamic stereo headphones, only headsets so guess it's not a competitor...Where did you order from
Amazon (dispatched and sold by Amazon)
Do they take them back if you've tried them?OcUK don't appear to sell Beyerdynamic stereo headphones, only headsets so guess it's not a competitor...
They have in the past when i've ordered Sennheisers that clamped my head like a vice!Do they take them back if you've tried them?
Thanks, great to know that any clamp force can be reducedHonestly, the weight is so well distributed they pretty much disappear when on your head. The good thing with Beyers being mostly metal is if the clamp is too tight you can just pull the two sides apart and lessen the pressure.
They should take EQ well too, I'm currently listening to Tool through my DT1990's with 3x 2db bass shelves at 150Hz, 100Hz and 50Hz so they stack as the frequency drops - it's like having a sub-woofer tied to my head and still no distortion.
When not being silly they are detail monsters - the DT1770 and DT1990 share the same drivers, it's just that the DT1770 is closed and the DT1990 is semi-open. I'm currently considering getting a pair of DT1770's myself to add to my Denon AH-D7200's and Sony MDR-1A's on the closed back side of the stable![]()
What EQ software do you use? I have an external Soundblaster G6 and the EQ in the software is quite rubbish. I cannot even appear to be able to add additinal points to raise / lower dB on the eq line
Here you go, just hover your mouse over the line at the frequency and it should change to allow movement:
DT1770s arrived today.
Short review
Very well made
Comfort - Very comfy, even with the weight. Just about the right amount of clamping pressure without it hurting my ears / head which I was afraid of
Drive - Rated impedance 250Ω but way easier to drive than my AKG 702 which are 62Ω. In contrast I would say it makes the 702s feel like 400Ω I left them on the same volume thinking more would be required and had to quickly turn them down when driven with a Soundblaster G6 on high gain.
Sound quality - Sound is so much more powerful and in your face than the 702s. The bass is fantastic and the Dolby Atmos 'Amaze' trailer sounds like you are sat in a Dolby cinema. Sounds stage is quite wide, but obviously not like the 702s which are open. So far i've only tried the velour ear pads so yet to try the pleather ones.
Phenomenally beautiful. How are they?
Do they not come with two cables? One longer XLR and one shorter 3.5mm? Or is that just higher models.
Try head fi classifieds for cable. Focal use 3.5mm terminations into headphone ports so you should be able to find a good one at a good price.
I cant see why not. i had dt880 250ohm and most things drove them petty wellAnyone know if the Fiio E10K can power the DT990 250ohms?
