Vision OC 3070 sticker lifting
6 Oct 2004
Southampton, UK
So I got this card a few days ago, thanks OCUK. Installed it into my rig and I noticed today that the purple sticker is lifting.
I don't mind having that sticker on there to be honest and im not sure taking it off will void warranty.
Anyone elses doing the same , or I just have a dud sticker.
Well I wonder what else is wrong with it now if they cant even stick abit of paper to the card. :D
Heat sink etc all ok? :D
Made a bit of a hash job with gluing it down with those dots. Kinda bent the sticker. Ended up taking the whole purple sticker thing off.
Any chance of getting replacement stickers at all ?
I have changed the led colour to match the others , but not sure if I like the look.
@Lustral
I got the same card on the Friday deal. What temps are you getting under long load?
Also, how do you control the RGB colours, do you need to install some software?
@Lustral
With my case fans on the lowest rpm 800rpm , im getting about 74-76C highs on a long session of Cyberpunk
Just search for RGB Fusion 2.0 and install that to control it.
