RTX runtime 4.2 - install files needed
14 Dec 2004
South
Hi all,
In a bit of a dilemma, I need to install RTX runtime 4.2 on a fresh windows NT 4.0 install. The old HDD failed and cannot be repaired.
I cannot find the files anywhere online, can anyone assist?
I think I've found as close as I can. Here is a link to RTX Runtime v4.3.2.1:
http://web.archive.org/web/20051024194531/http://www.vci.com/embedded/products.aspx?ID=218
Link is at the bottom, it'll download the saved exe. I'll continue hunting for 4.2, but wanted to report this in case it works for you :)
Don't spend too much time doing this, the license is on the old HDD and cannot find it at all.
I think this is a lost cause, on a positive note though, it was installing all the way up to needing the license, where as rtx5 died straight away
Ah :( That's unfortunate. I'd imagine the license key could well be in someones email, or filed away in a drawer somewhere. v4.3.2.1 was the absolute earliest I've managed to find, so don't worry about me spending time on it. I went looking because I thought it would be a fun challenge.
