I'm rebuilding my WC loop and I'm a little concerned at the high temperatures I'm experiencing. This this characteristic of this hardware?
I'm running an i5-11600k at straight stock settings. Running Prime95 I'm getting 87C CPU temps. That alone is probably OK but seems suboptimal for my setup like something is wrong. I've bled the system. There is no air. There is no other components in the loop at the moment.
I'm running a Swiftech MCR320-DRIVE-R3 which is a triple 120mm radiator (triple 1000rpm fans exhausting) with a DDC pump and res integrated. The waterblock is a AquaComputer Cuplex Kryos Next.
Is something going wrong here or is this a fair result?
Thank you,
Beefey
Thank you,
Beefey
