will stick with mine loud then lolPretty loud!
5 is okay…
I have Hd600, HD580, Sony 7506, Senn Momentum. I gave a pair to @Phate (the ones you see on TV with football pundits, and used by DJs), and threw away a pair of Senn HD495 as they fell apart.
And AirPodses. So only 4 pairs, and only the Sennheisers are consider audio grade.
I have the B&W P9s (closed back), the Nad Viso HP70 (noise cancelling), Sennheiser HD800 (open backed), Samsung 1000xm4 (noise cancelling, freebie) and Samsung buds pro (freebie) and the latest edition the Focal Celestee (closed back)
Closed back used for gaming and when somebody is in the shared lounge, I use the hd800 when I am alone.
Need to get rid of the B&W P9s and the Nad as they have all been superseded by better phones now.
I think you mean Sony 1000 XM4, I have one of those, it's for the plane and don't use it at home really.
The HD600 I picked up YEARS back in a sale, i think i paid like £120, it's left the box about 3 times. I use the HD580 much more, it's actually on it's 2nd set of pads and cables.
The shelf.
Room is still not finished.
The saturn v is not staying there and I still need to rearrange to make it less Busy.
I have a chaotic mind. It doesn't bother me. But I am cutting down. Rear shelving hasn't arrived.How do you cope with so much clutter on your desk?
Maybe another self and place the Saturn V horizontally?
I like the Loch Ness monster also.![]()
Here's the product pic. As it isn't clear in room pic.
The shelf.
Surface Headphones 2. I've been eying these up for a while, bit the bullet thanks to a good price.
Those speakers must be boomboxes with both of them being shoved into corners!
*Amazon.137 off the forest.
