- 8 Nov 2006
- Ireland/Northern Ireland Border
I'm moving house tomorrow and my PC is going to be boxed up and moved by the removals company.
It is going to be going into the box the case came in with styrofoam bits around it to hold it in place in the box.
Do I need to remove the cooler? It is an aluminium tower cooler
Cut a long piece and get it under the cooler base. Make sure it's between IHS and cooler base, not CPU PCB and IHS, then pull ends back and forth in a sawing action to get it to cut it's way in. Really need to remove mobo from case to do this.
