Try googling "ctrl alt stock discord" and it's right there. I won't patronise you with a LMGTFY link![]()
thanks mate,
also to clarify, do I just set the region to UK and select the GPU that infant alerts for?
or is there something I’m missing?
Braver man than me, I have over the last few years gained some life preservation skills.
Epic cat![]()
Haven't bought any hair 'product', bar shampoo, for over 30 years.
And I still don't know who Matt Clay is.
Whoever he is, he came second to Matt Finish.Haven't bought any hair 'product', bar shampoo, for over 30 years.
A Firestick, 2021 version.
You can get a plug that's got an ethernet socket built in to it.I'd get one of those myself if they had an ethernet port and didn't force you to use wifi.
I haven't actually used these but knowing Discord, there might be a bot or channel you subscribe to? @Karl may be able to helpthanks mate,
