- 3 Mar 2020
Ssupd stands for Sunny Side Up and is focused on the builder’s experience and emotion of using PC hardware and accessories to create and play. The lead designer and founder majored in architecture and has worked for Lian Li as a lead designer for years. As a leader, Ssu knows the importance of collaborating with other great design minds and brands.
The goal for Ssupd is simple: MAKE PC BUILDING INTUITIVE, PLEASURABLE AND FUN.
Ssupd Meshlicious Mini ITX Case - Tempered Glass - Black - PCIE 3.0 @ £101.99 inc VAT
SFF PC case, Combination of mesh panel and tempered glass side panel, Flexible interior layout, supports full-size GPUs up to 336mm in length, vertical or horizontal GPU mounting possible
Only £101.99 inc VAT.
ORDER NOW
Also In White
Ssupd Meshlicious Mini ITX Case - Tempered Glass - White - PCIE 3.0 @ £101.99 inc VAT
Ssupd Meshlicious Mini ITX Case - Full Mesh - Black - PCIE 3.0 @ £110.99 inc VAT
SFF PC case, All-mesh exterior, Flexible interior layout, supports full-size GPUs up to 336mm in length, vertical or horizontal GPU mounting possible
Only £110.99 inc VAT.
ORDER NOW
Also In white
Ssupd Meshlicious Mini ITX Case - Full Mesh - White - PCIE 3.0 @ £110.99 inc VAT
Ssupd Meshlicious Mini ITX Case - Full Mesh - Black - PCIE 4.0 @ £149.99 inc VAT
SFF PC case, All-mesh exterior, Flexible interior layout, supports full-size GPUs up to 336mm in length, vertical and horizontal GPU mounting possible
Only £149.99 inc VAT.
ORDER NOW
Ssupd Meshlicious Mesh Side Panel - Black @ £29.99 inc VAT https://www.overclockers.co.uk/ssupd-meshlicious-mini-itx-case-mesh-side-panel-black-ca-005-su.html
Mesh side panel, Compatible with Meshlicious PC case
Only £29.99 inc VAT.
ORDER NOW
Also In white
Ssupd Meshlicious Mesh Side Panel - White @ £29.99 inc VAT https://www.overclockers.co.uk/ssupd-meshlicious-mini-itx-case-mesh-side-panel-white-ca-006-su.html
[URL="https://www.overclockers.co.uk/ssupd-meshlicious-mini-itx-case-tempered-glass-side-panel-black-ca-007-su.html"] Ssupd Meshlicious Tempered Glass Side Panel - Black @ £19.99 inc VAT https://www.overclockers.co.uk/ssup...empered-glass-side-panel-black-ca-007-su.html
Tempered glass side panel, Compatible with Meshlicious PC case
Only £19.99 inc VAT.
ORDER NOW
Also in White
Ssupd Meshlicious Tempered Glass Side Panel - White @ £19.99 inc VAT https://www.overclockers.co.uk/ssup...empered-glass-side-panel-white-ca-008-su.html
[URL="https://www.overclockers.co.uk/ssupd-meshlicious-mini-itx-case-pcie-4.0-riser-cable-14cm-length-ca-009-su.html"] Ssupd PCIe 4.0 Riser Cable - 14CM Length @ £82.99 inc VAT https://www.overclockers.co.uk/ssup...ie-4.0-riser-cable-14cm-length-ca-009-su.html
Riser cable, PCI-E 4.0 connector, Compatible with modern GPUs, Angle adapter included
Only £82.99 inc VAT.
ORDER NOW
Ssupd PCIe 3.0 Riser Cable - 18CM Length @ £29.99 inc VAT https://www.overclockers.co.uk/ssup...ie-3.0-riser-cable-18cm-length-ca-00a-su.html
Riser cable, PCI-E 3.0 connector, Compatible with modern GPUs
ORDER NOW[/url][/url][URL="https://www.overclockers.co.uk/ssupd-meshlicious-mini-itx-case-tempered-glass-side-panel-white-ca-008-su.html"][/url]
ORDER NOW
Also In White
ORDER NOW
Also In white
ORDER NOW
ORDER NOW
Also In white
ORDER NOW
Also in White
ORDER NOW
