Deleted User 298457
Deleted User 298457
AutoGlym Ceramic
Careful with this. You need to ensure the standmount tube is sufficiently insulated to prevent interference from the stand's natural resonance.
I also suggest buying some one way cables to promote the warmest of sounds.
Have never heard of this before considering the holes in the standmount tubes being there at top and bottom for this very reason? Unless you mean cable tying the cable to the tube on the outside of course in which case I have no idea. My cables are as thick as a thumb VanDamne blues so there's no way any resonance interference will pass through that much shielding so never been something I've had to think about
One way cables though?!
You're too kind!
I knew something was up but given who posted the comment (someone who is otherwise reliable and accurate!) I figured maybe I wasn't "in the know"![]()
Speaker cable doesn't have shielding, does it...?My cables are as thick as a thumb VanDamne blues so there's no way any resonance interference will pass through that much shielding so never been something I've had to think about![]()
I could do with some shielding right now from the ensuing discussion I fear I've engendered with what was intended to be a joke.Speaker cable doesn't have shielding, does it...?
Fair point, and you got me with it as well. I wasn't gonna reply about the directional cable BS but I got sucked inI could do with some shielding right now from the ensuing discussion I fear I've engendered with what was intended to be a joke.
They really do exist (3080)
Nothing wrong with a 3080 TI. No doubt if I didn't pick this up I'd have done similar, luckily saved a little money grabbing this oneI wanted a 3080, ended up with a 3080 TI. You got luckier than me![]()
I got the same, God knows what look I would have got for 3080ti pricesNothing wrong with it except the glares coming from my wife as a result![]()
Tbh, I only use iplayer, YouTube and Netflix and already have those in my smart tv, but as I'm using wireless buds, I bought the Firestick because it has an AV sync adjuster. When I stream from the tv directly it doesn't let me adjust for bluetooth audio and often there's a bit of lag between sound and picture so hopefully the firestick will sort that out. Mine cost £40. The 4k version is £50.
Have been tempted to replace the Ibiza Fr with an earlier JCW! Looks great.A used Mini Cooper to replace the ageing Peugeot 206 we were using as a second car. Love the sunroof and it's incredible fun to drive. I absolutely loved the drive home. It's such a blast and the performance is acceptable in sport mode.
I then drove my Evoque straight after bringing this home and hated it compared to the Mini. I really can see me swapping the Evoque for a Mini JCW soon. I had been thinking of replacing that with a A3, Golf or something similar but I'm so impressed with this little Mini Cooper that I think a JCW is now right up there on the short list.
Couldn't resist for £100 each. Took 6 weeks to arrive but worth the wait.
