A little weave is actually best, people naturally focus on movement and it ensures you will not be hidden behind a pillar as you can fill the same road space as a carOr sound it as you approach a junction?
+ someone riding pinion going "wooo woooooooo" and waving their arms around.
Makes sense. I can't wait to see a photo of these guys at night with full hi-viz and reflective gear, covered in lights from head to toe because safety is so important to them.
Irate Italian = mumbo jumbo whilst making prayer hands?My gf has taken over the task of road rage for me. Fantastic having an irate italian telling people to go **** themselves while you focus on the road![]()
Indecipherable as mad or just talking passionately...
Yup, one big and one small will do me forever!! But couldn't resist them when they all cost me less than the RRP for the smallest knife...As a chef, I guarantee that you'll end up using just 1 or 2 of those knives and the rest will never get used![]()
Ride where they can see you then![]()
It's not. It's spraying all sorts of chemicals that knives don't like and generally bashing it around a bit. It's pretty well known that you shouldn't put decent knives in dishwashers if you don't want them to get blunt.How can a dishwasher blunt a knife? It’s just spraying hot water
Ha ha, brilliant. We've solved it!
**EDIT** I assume you think high vis doesn't make any difference either?
Anyway, I'll be leaving this discussion here. To suggest a louder vehicle makes no difference to if you are noticed by other road users is kind of silly IMO, why are their laws and rules being looked into (or maybe even in place) for electric vehicles making noise? Anyway, as said, I'll leave it there.![]()
In addition to the salt, I don't doubt it is also probably something to do with the 60 degree wishy washy things spinning and spraying chemicals/detergent and then sitting there drying off for an hour or two.Is it the salt in the water it sprays that makes it blunt?
Ha ha, brilliant. We've solved it!![]()
And the constant heat, stainless steel is only corrosion resistant at lower temperatures.Is it the salt in the water it sprays that makes it blunt?
