2 months after my build...
8 Feb 2006
Team Group 8Pack Edition 32GB (2x16GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit
MY-002-8P
be quiet! Silent Base 802 Midi Tower Case - Black
CA-146-BQ
AMD Ryzen 7 5800X Eight Core 4.7GHz (Socket AM4) Processor - Retail
CP-3CB-AM
Asus ROG Strix B550-F Gaming (Wi-Fi) (AMD AM4) B550 ATX Motherboard
MB-6FC-AS
Noctua NH-D15S Chromax Black CPU cooler - 140mm
HS-03R-NC
Seasonic Prime TX-750 750W 80 Plus Titanium Modular Power Supply
CA-076-SS
100% stable, no issues at all, super quiet, OCuk shipping was flawless. It boots in under 10 seconds, I thought my old i5 system was fast at 30ish seconds.
I see some people are still AMD hesitant, don't be.
I'm using an old 970 :p
Weirdly the only issue I have with the gpu is some artifacting on netflix using a 4k 65cx tv at 120hz.
Are you thinking of getting something else ?
Just noticed you have a 1000 posts so you can now use the member's market of the forum.
5800x is a beast of a CPU had mine since December 2020 couldn't be happier.
Was split between this and the 5900x but seeing some of the overclocking results and the fact I wont use more than 8 cores so glad I picked it.
Thank you
Forgot to say also, if you follow them make sure you hit the bell at the top right of their page and select notification for all tweets then you will get notified as soon as they tweet there is stock somewhere.
Also if your wanting an FE card you will tend to see that other EU countries get stock the same time or a day or so before the UK so once you see those notifications be on high alert
That’s really useful to know, I’m quite keen on an fe 3060ti
