NZXT CAM software not working
24 Sep 2020
2 weeks ago I built a new PC with an NZXT Z63 AIO as it looked to be one of the best looking and performing AIO’s on the market.
However 3 times in the last 2 weeks the CAM software has refused to load doesn’t matter how many times I restart the PC it just does not want to load.
NZXT’s solution is to delete the data from the root folder or something like that. Which I have done, but when you do that it deletes all your fan curves which is very annoying.
Has anyone else had this issue?
Do you have a solution?
Thanks
27 Jun 2005
Reading
I ended up doing the same. Just hope it doesn’t continue otherwise I’ll prob send it back :(
Can’t have the software not working half the time
Yeah to be fair it's normally fine for me but today just wasn't loading today. My first re install for a long time.
