Don't these blow head gaskets for fun due to inadequate cooling plus dodgy pipes? Get them to itemise the quote so you can go to Ford directly.
No they don't
Care to expand?No they don't![]()
Care to expand?
Right, but this is a literal thread where someones engine has overheated and blown the head gasket... so it seems relevant to talk about as Ford offered full cost repairs to remedy the situation.They aren't the widespread liability that some people here make them out to be.
That article you've linked is in itself lumping together 2 separate issues that affect 2 different engines.
The 1.0 had an issue with a coolant pipe which caused overheating (which should by now have been fixed via recall)
The 1.6 had issues with an overheating cylinder head, potentially cracking and causing oil fires.
I've owned my 62 plate 1.0 Focus for 5 years and it's done over 60k miles - listening to some people here and you'd think it would have grenade'd itself 5 times over by now
That issue was for focus that used a plastic coolant pipe insted of rubber. Plastic went brittle with heat cycles and eventually cracked coolant leaked out and you join the rover k series club.
Yeah, isn't OP car same era?
Sorry not a Ford Focus expert
i thought op car is a 1.6 na zetec?
Careful you may trigger a certain someone who has a sample size of himselfbah those 1.0's go pop too easily. good thing for ford they last the warranty period.
https://www.autoexpress.co.uk/ford/...ilures-company-pledges-to-pay-for-all-repairs
loads of sites with this info. new 1.0 ecoboost is less reliable than the cvh in old mk3 fiesta rs turbos. loll
3 year old article is old news - how many have blown up since the recalls have been completed?
around 134k as per watchdog report.
the so called "fix" only delayed the inevitable.
NoLink?
