Afternoon.
We're in the process of updating our garden, and one of the final areas that we need to address is a small area between the back of the house and one of the patio areas. We've left the patio raised by about 50-60cm (it was initially about 150cm) as we've a north facing garden and the area therefore gets good sunlight in the morning.
The old existing concrete laid many years ago seems in good condition - the patio has a several run off points into a lowered channel that deposits into a soak away.
I've read that you should look to avoid laying gravel directly onto a concrete slab as it can cause the stones to move underfoot and is a bit of a hazard. The area is quite small - 3.8m x 1.5m - and is rarely used. Our plan was to put down something like Cotswold buff gravel and I was wondering whether I needed to prep the area before laying the stones down? We're likely to be a couple of raised planters on it when complete to act as a mini-barrier so that people don't fall off the patio!
There's virtually nothing in terms of weeds coming through the concrete itself (just one or two near the edges) and the slab is angled down to the channel to provide good run-off. There's also a 5cm-6cm step up at the end nearest the door, and I was hoping this would help contain the stones somewhat or at least prevent them from rolling around when stepped on.
