So just recently been having a seemingly random tripping RCD. Tripped yesterday morning several times, I thought I had tracked down the culprit to a surge connector in the man cave as it then behaved all day, before tripping again last night.
Behaved again until it tripped again this morning.
This time it wouldn’t re-engage until I flicked off the the MCB for the man cave.
So this is where it starts to confuse my simple brain. I have 99% tracked it down to my new motion rig control box, but the socket it was connected to wasn’t turned on. Put simply I managed to get the power to trip off twice immediately after plugging that in again (turned off at socket).
That suggests a neutral to Earth leak tripping the RCD, but if that’s the case then why does tripping the MCD allow the RCD to be re-engaged since it is only breaking Live?!
There is a lot of EMI filtering in the box, which is probably most likely to blame. The real head scratcher though is that this morning if I plugged it in directly to the turned off socket using a 3m IEC cable then pop goes RCD. If I plugged it in through a different 1m IEC cable and a 15m extension lead then it didn’t pop…
So that leaves me confused.
Basically the head scratching revolves around the fact that if it trips with power switch off, it should be N-E fault, however flipping MCB allowed me to reset which only cuts Live.
If it’s the EMI filters causing it, why is it not consistent and only randomly cutting out seemingly in the morning and evening? Why does it not fault when plugged it through a different IEC cable and extension?
If it is the IEC cable, why doesn’t it fault with the cable plugged in to the wall socket, but only when the cable is connected to the motion control box?
I am confuzzled.
I am confuzzled.
