Deleted User 298457
Deleted User 298457
Are you new here? Moon man is the famous screenshot of a photo man.Is that a screenshot of a photo?!
You'll see his posts in a whole new light now. I like it. It's like modern art.Never noticed before! Or forgot and noticed again all fresh and new. Life is exciting like that.
It definitely isn't cheaper to buy a loaf! The real cost with bread machines is the cost of the machine itself, and you got it for free, so you're very much quids in.Probebly cheaper to buy a loaf but something to play with and tweak, adding chilli olive oil ect
Bread mix can be slightly pricier than just buying strong bread flour and yeast, then adding your own oil / butter / salt / honey / so on. There's pence in it all really.It definitely isn't cheaper to buy a loaf! The real cost with bread machines is the cost of the machine itself, and you got it for free, so you're very much quids in.
Mines a little pale compared to yours, maybe an hour wasn't ideal![]()
Raymond's isn't straight ciabatta - if it was, I'd be eating yours any day over his! Yours is a fine colour for that, though possibly yes a little light. But if it tasted good, then who cares.Mines a little pale compared to yours, maybe an hour wasn't ideal![]()
Very true, this was my ciabatta but cunningly shaped like a loaf, came out great tbh didn't stick
Damn you all, i always look at bread makers and then get scope creep and end up discounting the cheaper ones and looking at expensive ones and then questioning whether i want to spend £300 on one and ultimately give up my search.
I'm finding though that these days you can easily spend £3 on a loaf in Waitrose if you want something specific.
That's not bad actually, out of interest how much was it on Prime day?
Pfft that isn't a shed
Is that a goose/other bird ready to stand and bang through the right hand window??
