- 23 Jun 2021
- England
see when i boot my cpu temp is 50 degrees then a few minutes later goes down to about 38. i think im fine if i can nail a few settings
does the usages of tdp, edc, ppt and cpu power matter that much?
yeah ive tried setting new limits and temps are WAY lower. why on earth are my stock pbo limits set stupidly high??There's a point at which if you lower them too much then performance won't be what it could be. If you try what I suggested with EDC and check the cinebench scores you may find same performance at lower temps. Shaving 15C off as you've already done is already very good though, if performance appears to be the same with no downclocking on load.
the rad isnt too hot.
From what is looks like is you have a manual OC so to translate this to bios you would need to set the CPU multiplier from auto to 46 and change the CPU core voltage from auto to override then punch in 1.27Hi all. Posted this in CPU cooling but having read this thread, this looks a much more appropriate place (made a few edits).
Wow its been many years since I last posted here, wonder if anyone remembers me!
I've recently made my way back to PC gaming, and love it.
So I've got a 5800x at stock using PBO it ran 4.7ghz 80c in game (max) and 90c Cinebench. I downloaded the Ryzen Master app and tested it out and undervolted got it to 1.27v @4600ghz. Cinebench runs solid at 80c and games at 60c (a drop of 20c). So now I believe its best to translate this into overclocking in the bios? My question is what exactly do I have to do? I'm new to overclocking and there's too many options I don't understand to just try things out and see what works. The motherboard is a MSI B550 Tomahawk, with a Black Rock 4 Pro Cooler.
Would really appreciate is someone would tell me what options to change within the bios. It dosnt have to be exactly like for like as the Ryzen Master overclock, I believe an offset negative voltage is preferable reading this thread? On Ryzen Master its showing at 90% EDC limit of 140a been used when I "test and apply" that overclock.
