The Series X is an overall superior experience to the 6800 / Ryzen 3600 system I was running previously. I would need to upgrade my motherboard, cpu and GPU to exceed the series x in most (but not all) performance aspects.
Does the image quality of the xbox match up to PC then? (genuine question having never seen one in action). I was under the impression you had to sacrifice quite a lot of settings to maintain the 4k/60fps
I am running a 1440p / 240hz monitor so can only experience 1440p / 120hz on Xbox but I would say the image quality is excellent on Xbox. I think all of the games I have played so far in Xbox have either played at 60hz or if they haven't I couldn't tell because of VRR. I have never once thought to myself "I bet this would look better on PC."
Then you have game load times which are faster on Xbox than PC, the ability to swap between games in less than 10 seconds, a better and bigger selection of gamepass games than PC, games just work without having to find optimal settings in the options menu, an included low latency controller in the box and a near silent machine in an attractive small form factor design.
For me the only advantage PC offers is higher FPS. 60hz is enough for me though and I am considering selling my Alienware 240hz monitor I got 6 months ago and getting a good 4K 60hz instead to make the move to Xbox permanent.
I have been a 21:9 user for years, I can't go back to 16:9 now... looks too small.I couldn't go back to a console controller again after spending years honing my mouse and keyboard muscle memory. And not sure I could game at anything other than 21:9 Ultrawide now either![]()
Fair enough - they've definitely come on significantly since I was in the console game then!
Still don't think personally I'd ever swap exclusively away from PC, but I can see how it would be more appealing to someone not already "in the game".
Is there no way to game at 21:9 but stream the output as 16:9?I was thinking the same when I had my 34" Ultrawide for gaming & it was awesome but not so for streaming, I moved to a 32" 1440p monitor & it's great for both, I might not have been thinking that if I'd gone back to a 27" model though.
Definitely, and that extra screen at the edges really helps you see enemies in shooter games. It's really handy for flying planes in Battlefield as well because when you are behind an enemy plane you can see which direction he pulls off in. It's like having the benefit of a wide FOV without actually having to have a really unrealistic looking FOV.I have been a 21:9 user for years, I can't go back to 16:9 now... looks too small.
I had a 42" 1080p screen for years before my 34" Ultrawide, I can't imagine gaming on 27" 16:9. I actually still use the 42" for sim racing because even the 34" Ultrawide is too small for that.
