Car suddenly very loud...
Caporegime
4 Jul 2004
Drove to work this morning and everything was fine. Started it up after work and was met with a sound that can only be described as chav boy racer exhaust...
Put it this way, when I accelerate everyone turns their heads because it's so horribly loud.
Is this a common issue, and is it expensive to fix?
Thanks :o
2 Mar 2004
SE England
Strange for it to change so quickly but there's evidently an issue with the exhaust system. Has someone sawn the catalytic converter off?
Otherwise, it's impossible for us to tell you what's required, unfortunately, without actually looking at it. Take it to a local garage, if you can, and get it up on their ramps.
Man of Honour
19 Oct 2002
Surrey
Is it only noisy when accelerating and is normal when idling?
Hopefully not a cat theft and it's just a hole etc.
Caporegime
OP
4 Jul 2004
Managed to squeeze myself under and found the culprit. Pipe has come out of the back box... I know hardly anything about exhausts but I'm assuming this could be a rather quick fix and nothing too serious? Although it does look rather rusty...
Thanks all.
Caporegime
OP
4 Jul 2004
Absolutely no idea how I didn't notice this before but there is a crease in the middle of my bumper so some **** has hit it. There's also a scrape/dent down the rear wheel arch! Hit it once in the rear and then somehow managed to hit it again when they've pulled off? Ffs, how?
Man of Honour
19 Oct 2002
Surrey
That's annoying. I bet when they hit the rear bumper it pushed the exhaust in and snapped it at the rear box :(
Any cameras where you were parked?
JRS
JRS
6 Jun 2004
Burton-on-Trent
Skill and judgement, I expect.
