Does this look right?
No overclock
Valley Preset = Ultra
Res = 3440x1440
GPU was 74-77°C after about 20 mins because it's hot today (about 26°C outside) and I have a custom curve to keep it quiet. With the fan speed set to 100% the temp went down to 65°C but the core clock didn't increase so I assume at 74-77°C it wasn't thermal throttling.
FPS 160-260
GPU Clock 1575-1890MHz (averaged about 1700MHz)
CPU Clock - Constant 4805MHz
Giant image so you can see all the numbers, click to enlarge.
I was going to ditch my fan curve and try a little OC just for fun but Valley seems to make my core clock just fluctuate wildly so I can't really see what max MHz it's actually running at. Is there a better stress test to run that will just pin the core clock to it's max constantly?
Seen a few YT videos of people running Valley with OC's and their GPU's sit at a constant clock of 2xxx, am I doing something wrong? I tried upping the power and temp sliders as usual and increasing the core clock but it had no effect on the reported core clock (yes I did press apply) as it just fluctuates a lot.
I would post my 3dMark (demo) score but their site doesn't seem to be working correctly right now.
No overclock
Res = 3440x1440
FPS 160-260
