Although.... disco inferno!
/badass.gifYou can, I don't use iCue so am installing it just to turn the lights off then uninstalling again.
Thank god you've removed any signs of natural life from your garden![]()
This. Really weird choice for a patio material. But if you're happy, that's all that matters.My eyesTruly hideous that
There is only 1 question on that patio, it might be the photo but is there a gradient built in away from the house? If you see where i am going with this?
It's the photo, the surface is level.
That certainly is an expanse of bonded resin It could be the angle of the pictures but does seem to grade towards the house?
Hope there is some drainage channel, gravel or something to soak up / disburse the run off
You don't want it to be "level"...you want it to slope slightly away from the house.
If the surface was impermeable, then yes. But the surface is permeable so any water goes straight through to the sub base. It won't run towards the house.
Anyway, it's "level" as opposed to level, there is a very very slight slope towards the fence.
