Images of items I have purchased (except trainers)
9 Dec 2007
Hants
Went to buy a Golf R, with having a young family I was put off by the horror stories i hear of House/Car jackings. So I bought something nobody would want to steal..
been driving a VRS estate TDi for almost 3 years now. been faultless tbh. and not a bad handler for its size, think its technically a golf chassis which is normally pretty good?
mjt
mjt
31 Aug 2007
A fine choice. I'd still be using a pair if the battery in the right one hadn't packed up.
How long did they last? That's a bit concerning!
Honestly, these won't get much use as I drive to work and thanks to Covid travelling is a thing of the past :(
But I'd be annoyed if they broke after a year or two!
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Do like that, you did install some hidden compartments or leave a dummy skeleton behind some panelling right? That would be my primary mission objective, the long con for the next owner of the house to discover :D
Man of Honour
20 Sep 2006
(posted in the 'man jobs' thread as well)
Bought two lots of shelving for the garage, unsurprisingly Hermes have managed to lose one of them although I've just been notified they are bringing it later on today. I have the afternoon off so put up the first lot turning this:
Into this:
Once the other one is up there should be a lot more room for the Civic. I'm unsure if I should bother bolting them to the wall, the BMW OEM diff is in the blue box at the bottom and is far from light.
Frustrating that it's so hot outside although the garage with both doors open did offer some respite from the sun and there was a nice draft. I'm still drenched though!
4 Jun 2020
Because they match the rest of the decor (coving, colour scheme etc), rather than a row of kitchen units dumped in a straight line in an otherwise modern looking room?
Im getting similar units soon in a bare and empty room and everyone calls it kitchen units. Nothing looks modern or such, its a fully empty room with just blinds, carpet and plain white walls.
Everyone argued that shaker units are for kitchens only, not lounges. Hypocrisy.
Because they're (rightly) positioned where it's natural to have them: an alcove. And he made them. And they look good. :p
Hypocrite.
29 Jun 2016
Up Norf
Yeah you're right, its basically a long wheelbase golf. Mine has a LSD so it really does well in the corners.
20 Feb 2004
Hondon de las Nieves, Spain
How come theres no comments of 'Kitchen units in the lounge' like everyone loves to give me? This place is so inconsistent.
As mentioned above, generally because there's 2 of them either side which is quite common for alcove units, they look fitted to the surroundings. Not a row of 6 units along a wall which is typically a look you would see in a kitchen/utility room.
Man of Honour
19 Oct 2002
Surrey
OK, if it makes you feel better I'll pick on a couple of points...
@Mason- Not sure my OCD can deal with the poor edging of the blue paintwork. Also why didn't you take the opportunity to embed the radiator pipe into the wall during renovations, or at least paint the copper half white. You monster!
(Love it Mason)
18 Jun 2010
Essex
(Love it Mason)
It looks better in person but you're right I could have cut in around the caulk line better. A sofa will be going along that wall, I could have done it, but didn't see the point it was always gonna be where the sofa is going. I am going to slap some hammerite on them though (white). We buried a radiator pipe in the hallway too... what a ball ache that was, so much bloody dust angle grinding the concrete floor up.
