Morning chaps, best product for trim restoration back to black so the trim is nice and dark!
Thanks
I use Gtechniq C4
Thanks
PERL is my go to. https://www.cleanyourcar.co.uk/carpro-perl-coat-protectant
I have a £50 Halfords voucher for some car cleaning stuff, any recommendations? Meguiars and Autoglym still good stuff?
Thanks
Update to this - tried the colour lock dye in their matched BMW Opal White... Colour came out looking more yellow/egg shell then white and I'd say the seats look a lot worse now... Customer support so far has been woeful, with the only advice they have suggested is to "shake the can" which I had done so prior to the first application and in between coats...
I purchase some AD purple rain as it was being sold on Amazon for just over £5 so thought I'd give the car a quick wash before it got to hot.
Really impressed with the product and has cleaned the wheels great.
Also I posted about GUNK TFR as it was £6 for 5L of the stuff, so used that today in the snowfoam gun and again really impressed. The process today as follows:
Purple rain wheels
After 5 min I snowfoamed the entire car with the GUNK.
Left 5 minutes and pressure washed.
Contact wash using some cheap cherry shampoo
Rinse
Dry
Finished with Astonish Spray n Shine
I've recently bought a rotary polisher and some G3 polish. The car is having a big service this month which includes cambelt and water pump, DSG oil change and it's also had 2 new tyres so thought I'd give it a polish in a few weeks time as I've never polished the car in the 6 years I've had it!
Anyway results from today:
normally wash the car and use the soap to do my alloys, but if i just wanted to give my wheels a clean now and again (because of brake dust of course)
what PH neutral alloy wheel cleaner would you recommend ? (so wont corrode the alloys overtime)
i might check out the Bilt Hamber one ...
Checkout garage therapy wheel shampoo.. Has a bit more bite than your normal shampoo but not as harsh as a wheel cleaner... Since I've started using it I've not had to use anything stronger like Bilt hamber
woooah
what a colour difference !
Seat supposed to be white or grey ?
