Hello All,
My pc build is currently as follows:
Intel Core i7-10700K + CoolerMaster MasterLiquid ML120L V2 RGB
NVIDIA GeForce RTX 3080 10GB
Corsair 750W TX750M
ASUS PRIME Z490-V
be quiet! Pure Base 500 Window - Black
16GB Corsair Vengeance RGB Pro 3200MHz (1x16GB)
Seagate 500GB BarraCuda 510 NVMe M.2 SSD & Seagate 2TB BarraCuda HDD
I have a couple of questions so I hope you will bear with me!
- I would like to get another stick of 16GB ram and run them as dual 32GB + I would like to get another nvme m.2 1TB and run that along with the current 500GB SSD + 2TB HDD.
* I've had a quick skim of the mobo guide but I'm not 100% sure so could someone please confirm that I'll be able to do the above upgrades without any issues? No extra cables needed for extra ssd nvme?
* By adding the extra ram/ssd am I going to need more power?
- I would like to upgrade from 1080p 144hz now to 1440p 144hz with a monitor costing about £300. Does anyone have any recommendations for that budget? I'd like either 24-27" ideally but wouldn't want to go on the larger end if it meant sacrificing quality/performance etc.
* Should I go with a display cable over hdmi for the res increase? I don't think the hdmi cable I currently have is only the high end. Will this come with the monitors or am I going to need to buy it seperately?
Thank you very much for your time!
Corsair 750W TX750M
ASUS PRIME Z490-V
