Are Brembo a decent choice?
Looking to do disks and pads all round on a Skoda Superb. Are Brembo a good choice or what would you go for?
Try MTEC brakes, I've ran them for years! Spray them with caliper paint (keeping as much off the main rotor) to protect them, they'll last for years.
I swapped to Brembo discs with ATE pads all round about 6 months ago. They've been good as an OEM replacement, same performance and quality plus saved a good bit over genuine BMW parts.
