Thankyou so basically it’s easier to cool the 5900x so I might as well get one of them!It's because the cores are split across 2 separate chiplets in the 5900x (2 x 7nm chiplets with 6 of 8 cores active in each), so heat is dissipated over a larger surface area, whereas a 5800x has just a single 7nm chiplet with all 8 cores active, which makes getting all that heat into the heatspreader very difficult.
I hear a lot of complaints about 5800 temps but not so many about 5900 temps.
Is this because the 5900 is a better binned chip or just that it’s owners generally run between cooling?
Thankyou but I’m guessing these aren’t advertised as such?Brazo, Just to make you aware there, out in the wild 5600x (6c/12)t & 5800x(8c16t) that have two chiplets. They are failed 5950x and 5900x, with one being disabled. These also will be cooler than normal 5600x & 5800x
