Caporegime
- 8 Jan 2004
- Rutland
That said, I have more disposible income thanks to a new job
Marketing for a certain mediocre CPU maker?
Nope, needed a new CPU for the games I play, wasn't prepared to wait.
That said, I have more disposible income thanks to a new job, so will likely jump on a DDR5 platform to play around sooner than later![]()
LolIts a Dave2150 thread. The thread is 100% certain to be factually false.
Will this 12900k hybrid be a little problematic when it comes to all core overclocking, considering some are small cores and some are big?
That’s problematic. The reason I wouldn’t choose AMD to be honest.
I buy Intel for the ease of overclocking all cores, I don’t want to have to overclock the same chip twice.
If the 12900k is a hybrid containing both big and small cores, then it would be more time consuming and problematic to overclock. AMD are more optimised and don't require overclocking.
If the 12900k is a hybrid containing both big and small cores, then it would be more time consuming and problematic to overclock. AMD are not as good for overclocking.
Overclocking is dying anyway. Leaving significant performance untapped isn't happening in an era of complex per core boost algorithms and power limits.
Part of the reason Intel have more headroom is their older process and architecture let's them chuck silly amounts of power around for the gains available.
AMDs 7nm process is much more efficient, doesn’t respond as well to more voltage/power and their boost algorithm does a pretty decent job at getting what's possible out of their chips.
I suspect future CPUs will move towards overclocking being largely pointless (Zen 3 isn't far from this) much like on GPUs these days.
I can still get 200 to 300Mhz out of my 5800X to get it to 5Ghz or higher, its not great but its already tuned to run at high Mhz out of the box and i don't think that's any worse than Intel CPU's from the same generation, in fact they already run at 5.2Ghz out of the box and so far as i can tell they don't even run so much as 100Mhz higher than that reliably overclocked unless you get a rare sample.
Also AMD's 14nm chips were twice as efficient as Intel's, these 10nm chips (supposedly better than TSMC 7nm, according to Intel) still run at well over 200 Watts. Again twice the power consumption of AMD's chips.
Is it just the process node or does architecture also play its part?
Seeing as Intel’s fabs are open for business and Intel want to buy GloFlo I doubt Intel’s production is better.
thats not standard 5800X though, with PBO auto mine would be at 142W PPT @ ~4550
Can you get 4800-4900 on yours on a CB multi run ? impressive![]()
It's probably clock stretching if your getting these clocks in multicore, what score are you getting?Granted, i have a -15 Curve optimiser on it, the cooler also keeps it around 70c full load.
Sceptical here to say the least
