Thanks will hold off for now and see if anything is updated in the September eventThere's been rumours that there might be an updated base iPad and or iPad Air so yes its possible that the non-Pro iPads will get an upgrade this year
if you need one now and the current model fits your requirements, what are you waiting for?Hi looking to get a new iPad 10.8” or 11” and wondered if there will be any be any new ones in October?
Thanks
Had a 10.8” pro for a while now and just fancied a new one so no rush, just didn’t want to buy one and a new one comes out shortly afterwardsif you need one now and the current model fits your requirements, what are you waiting for?![]()
Can’t see the Air getting a refresh, it only got one last year. Plus the only thing it’s ‘lacking’ is the 120hz display which I personally can’t see them using because it would eat into the iPad Pro market.It’s looking likely that we will get a new mini this autumn. It will be nice if they also refresh the Air. I am still running an Air 2, I can’t believe how long it’s lasted, and it’s due to get iOS 15 too!
And the M1 chip but I had to ask, I also thought it was longer since the air updated oh well I can wait a couple of months and keep using my proCan’t see the Air getting a refresh, it only got one last year. Plus the only thing it’s ‘lacking’ is the 120hz display which I personally can’t see them using because it would eat into the iPad Pro market.
The M1 chip did come to mind however bearing in mind it’s overpowered for the Pro even if it WAS in the Air it would be total overkill.And the M1 chip but I had to ask, I also thought it was longer since the air updated oh well I can wait a couple of months and keep using my pro
Hoping for a new mini iteration with a different design approach.
