Hi All
Bit of a strange one here, I had a 500gb M.2 Western Digital drive which was nearly out of space, so I purchased the Evo from MM plugged it in to the second M2 port, created and image to the 1TB (which worked perfectly). Shut the PC down and moved the 1TB to port one (M2) and it won't see it in the BIOS, I flashed the BIOS to the latest, still nothing, so both ports work as expected I just can't get the new EVO (OS Drive) to be seen by the board, not a major issue but that's where M2 heat sink is from factory other wise I'd have to buy a new heatsink for port 2 (if that makes sense)
Any ideas before I give up
