A large amount of them have a real contrast ratio of between 700:1 to 900:1 unless its a VA which has better contrast but suffers from blur/smearing in movement. 700:1 to 900:1 seem to be common real contrast level for some types of screens.What kind of monitor nowadays has a 700:1 contrast ratio?!
HDR10 is an input signal source and doesn’t tell you anything about the screens ability to handle that content and do anything to actually display an HDR image.
the HDR600 screen is almost certainly the better option here but can you share details of both options so I can look a bit further and provide more advice?
Yes I realise that but the vagueness of the original post suggested he was referring to a listed spec so I was curious to see which model was being looked at here. Something didn’t sound right…A large amount of them have a real contrast ratio of between 700:1 to 900:1 unless its a VA which has better contrast but suffers from blur/smearing in movement. 700:1 to 900:1 seem to be common real contrast level for some types of screens.
I would say real contrast matters more then HDR. Without good contrast HDR is useless then again with how badly windows handles HDR even good HDR screens can look terrible.
Ok thanks. Much easier. Those two models are based on the exact same panel from LG Display and have the same specs. Both are listed with HDR600 support, and both have a 1000:1 contrast ratio spec. I think the confusion around a 700:1 spec is because the 95C model also bothers to list a “minimum” contrast ratio spec, whereas LG didn’t bother including that with the 950, even though it would be identicalThe 2 monitors are:
LG 38WN95C-W
or
LG 38GN950-B
Hood
There's nothing making them automatically better.Of course a true HDR capable monitor might also be better in general than one that isn't
By "true HDR" I meant a display capable of a suitably high brightness level that meets one of the standards set by VESA - as opposed to the ones marketed as "HDR10" which is not a form of HDR recognised by VESA. Also you quoted only part of my post, I qualified that statement with "but that's not certain by any means".There's nothing making them automatically better.
Because some "true HDR" is marketing BS to hide that there's no advance in flat monitors with LCD panels still having same old broken contrast. (compared to self emissive pixel displays)
True high contrast like in OLED is what would automatically improve image quality in all content.
Why is the 950 a gamers screen and the 95 isn’t? They look very similar in specification and function to me.
Edit: are there any better alternatives for gaming with some work?
Hood
Also the same panel as those two LG screens. The specs will be the same on all but the features will vary. Good explanation about about why the 95 is more aimed at office users and the 950 more at gamersAhhh now the Alienware AW3821DW enters the ring.
So frustrating having to decide which flippin’ expensive monitor to get!
Hood
