steering wheel worn question.
10 Jan 2011
Hello all,
My current steering wheel is warn and the stitching is coming undone. I'm looking for one on eBay the exact one for my car is selling without a airbag, so my question is can I get the air bag removed from my wheel into the new wheel?
I've googled it and I can't get an answer.
Yes. It'll have retaining clips of sort. Check your Haynes manual. Providing it's an identical wheel of course.
What car out of interest? I've done it in several Fiestas and it really is a piece of cake.
Citroen DS3 Airbag Removal (Ranya Salvage ) - YouTube
Seems like a piece of cake too.
Have you thought about getting your steering wheel refurbished instead of getting a new one? Obviously depending on how much it is for the new (used) one on ebay.
EDIT: ok, just looked, they are about £40 from ebay from good quality ones. As you were :p
And he'd still need to remove the airbag to take the wheel off...
Just an FYI
I replaced the steering wheel on my Fiesta and while it was from the same model, it came from a slightly newer car.
I put my airbag in and it didn’t work. Thankfully, it did come with its own one.
air-bag process is not hard,
but (bmw experience) the clock-spring type wiring module that enables that&wheel buttons to connect into car can be fragile/ageing,
and you need to make sure it remains wound at same point when you put wheel back on.
