New kitchen, oven / hob/ worktop clearances
Don
18 Oct 2002
Notts
Having a new kitchen at the moment specced with 20mm worktops
having a right hard time sorting oven/hob clearances
really wanted a double oven (built under) and have a Smeg one on order but now it seems that there won;t be enough clearance to the gas hob, even if I go for a thicker worktop I can't seem to get it all to come out right
even with some single ovens the clearances don't seem right
surely I'm doing something wrong
any ideas?
You'll struggle with that, I've seen installs with the really slim worktops where they put an induction hob over a draw unit. Then can't open the top draw :rolleyes:
You could fit oven with units either side both with end panels and use that as mounting point for double oven allowing it closer to ground.
I'm changing to 30mm worktops but still don't see how it can be done
there are units with end panels each side so we could drop oven a little but I don't reckon it would look great
The oven will basically be a cube that goes under the worktop, sitting on a shelf. The hob that goes into the worktop is thicker than the worktop, and its bottom (that you can't see) protrudes under the bottom of the worktop. That means the oven needs to be lower to allow this, so you make the shelf lower. Then there is normally some sort of trim across the front that hides the gap, such as a stainless strip that looks like part of the oven, but is actually there to hide the space. It could also be done by cutting out a hole lower down the cabinet and leaving wood as the trim. It's worth having some sort of reinforcement on that narrow strip in front of the hob (my quartz worktop has steel rods embedded into it, and I have seen marble worktops broken in that spot if they are abused).
Depending on the hob/oven, you may need to have ventilation gaps in the back and bottom of the unit to allow airflow into the bottom and out the top/back.
yes unfortunately the oven is 720 high and the units are 720 so lowering the oven will put things out of line
Get a range maybe, they come in 60cm so its going to end up just like you were in effect going to get?
Or maybe look to see if you can fit a wider range for those times when oven space is a premium?
a 60cm standalone cooker is an option but the cooker/hob is close to the end of a row with just a 150mm cab on one side so I am concerned that a unattached piece of worktop that size would look odd
We had a 150 cabinet next to a 900 range at last house and it looked fine.
Double built unders do have quite small cavities but obviously christmas is the biggest hurdle there.
I think that'll look odd despite what others will say, that is not a good design choice IMO.
We swayed away from double under counter oven for this reason, I hadn't realised how tiny the cavities were until I went to look at one. You also can't get 'self cleaning' in double form (you still have to clean it...just not as much).
For those talking about cabinets, a double undercounter oven is a free standing appliance, there is no cabinet for it to sit within. A normal single undercounter oven sits in a cabinet though.
