Cumulative Update Preview for Windows 10 Version 21H1 for x64-based Systems (KB5004296)
Caporegime
8 Sep 2006
On Ocuk
Cumulative Update Preview for Windows 10 Version 21H1 for x64-based Systems (KB5004296) : Windows 10 KB5004296 (21H1, 20H2) released with performance fixes
(Windows 10’s gaming issue causes reduced frame rates and ‘lower than expected performance in games’, according to support documents from Microsoft. This has been a known issue since this year’s April cumulative updates, according to our own tests and user reports.
With KB5004296, Windows 10 gaming issues are finally fixed. For those on Windows 10 version 21H1 (May 2021 Update), they’ll be getting Windows 10 Build 19043.1151. If you’re on October 20H2 Update, which was released in October 2020, you’ll get Windows 10 Build 19042.1151 instead.)
https://www.windowslatest.com/2021/...96-21h1-20h2-released-with-performance-fixes/
Heads up, the first "performance fix" preview is out
Already picked it up.
I had the workaround activated but installed it.took quite a while to install considering its size in mb.
500 normally takes 2 minutes on my system if that this took 5+
Did notice a change in fps though lot more consistent and less jumping spikes
