My Series X loads it nearly instantly from quick resume…![]()
And now you're lying, The Ascent does not support quick resume
That's the one the Cerny has tweeted about earlier. I guess that's a pretty high recommendation then!
These things aren't as expensive as I imagined they'd be.
Its nice to know that people are playing so little on their consoles that the only entertainment they get is talking about whether something loads in 7 seconds or 8.
Good stuff.
I have a steelseries one which is decent but tbh most of the time I use my Bose ones as they sound better. I never use the microphone so no idea how good they are for that….
Bose ones work with PS5?
Not directly I use Bluetooth to my tv….
Oh I see.
I guess I could plug in any headphones into the controller that way too? There is a mic in the controller doesn't it?
You could if you don’t mind having a lead. There is although I have no idea how good it is I have it permanently muted.
Cerny bought the heatsink version that WD think is somehow worth an extra £40.That's the one the Cerny has tweeted about earlier. I guess that's a pretty high recommendation then!
Nearly £200 for a mere 1TB, how expensive were you expecting?!
Oh I see.
Yeah I got the drive for £160 and an aftermarket heat sink that will probably be better.I imagined they'd be £220-£250ish and from the post above this one I guess that's about right with the heatsink. £170 didn't seem too bad when I looked at it yesterday.
Still can't decide on a wireless headset.
Sony Pulse 3d - Good price, uncomfortable.
Steelseries Artic 7p - Looks comfory, but Micro USB? What is this?
Syn Air - Non-replaceable ear pads? Just no.
Astro A50 - Overkill? Too heavy?
What would you guys get? I've ruled out the Sony because i am kind of regretting on my Xbox headsets for not being that comfortable...but I will have to live with it.
I've got a steelseries. The Micro USB is exactly what it sounds like. If I'm using it on PC it connects using the micro USB cable and when used on ps5 you have a tiny extension that plugs into the controller from the micro USB.
