A few months ago I wrote here about how the landlord had kindly installed a new boiler for us, a combi one. Following this there were two issues when an untightened nut caused a flood in the hall, and next an imporperly-wired connected caused one of the sockets to start burning.
That events were noted here:
https://forums.overclockers.co.uk/t...ipe-nut-work-itself-loose-over-time.18923103/
Now the issues have continued. Bear in mind this was a NEW BOILER only installed earlier this year.
On Thursday last week I was doing a Twitch stream and then the computer power shut off, I was like "what the hell?" and I found out that the RCD had tripped. OK, weird. We reset it but couldn't work out what had happened.
Next day in the evening, we find out that there was no hot water. The 'repair man' hired by the landlord [I use quotes because he 'fixes' something then causes another issue] came round and couldn't work out the problem. He came back again the next day, on Monday, and concluded that a fault in the boiler had caused the RCD to trip. This is now the third time there's been an issue with this new boiler.
Since then, it has been a comedy of errors, with this repairman and his colleagues showing up late and not being able to diagnose the fault. The bottom line is that it won't be fixed till at least Monday now and we have not had hot water for a week so far.
The landlord wrote to us this morning to say he would contact us after it had been fixed to give us his proposal for compensation. What would it be in this case? Repayment of rent for each day inconvenienced?
