- 22 Feb 2014
This is a bottom hinged oven door, the type where you open the door fully and flip down a small lever on the hinge to enable you to remove the door.
(grill door is same mechanism and seals fine)
Its not quite fully sealing at the top allowing air to escape
I have just replaced the hinges with brand new ones thinking that would cure the issue and whilst it is probably marginally better it isn't full sealing
As a test I fitted the smaller grill door to the bottom oven and that seems to be seating correctly, the seal looks ok and there don't appear to be any restrictions preventing it shutting.
when I push on the door it will fully seal but only as long as it is held.
I can't see any adjustment on the doors/hinges to correct this.
These are the hinges
https://www.ransomspares.co.uk/parts/search/hinge/hotpoint/cookers-hobs/dhs53cx/b/c/m/
Am I missing something obvious ?
