Greenlizard0 PL & Championship Football Thread ** spoilers ** [13th - 15th Aug 2021]
If Pogba continues to put in this kind of effort all season, then he’s alright in my book :)
I mean, I'm not sure any of his assists have been "effort" based. There has never really been any argument over his quality. The issue is when the team is under the kosh or he is asked to be more disciplined he doesn't do it. Against teams that give him time and space hes exceptional but then he should be for his wages.
OH MY! Fernandes you beauty. That was just casual. I'm not even sure I ever doubted that was going in. Belter!
It was sort of tongue in cheek, I typically moan about Pogba and don’t think he’ll keep up his interest past the next few weeks and will taper off.
No offside check? that looked like a candidate for VAR drawing lines with Microsoft paint.
Just mentioned that theres something about wider lines being used for offside this season or something, should lead to less decisions made because someones shoulder was 5mm ahead of the defender.
It was checked. They said they’re doing thicker lines this year - according to BT
no idea what that means but they said we’d have had 20 more goals last season with thicker lines….
Which we no longer get to see now.
changed my captain to salah last night
Penandes with a hat trick of non penalties. How did Portugal fail to use this man?
Because he isn't Ronaldo and Portugal will waste the next X years until he retires indulging an ageing Ronaldo while a golden generation of Portuguese talent is held back. Hes Portugals Rooney.
Looked like Ayling was playing him on to me. They're not showing us the lines any more though are they.
I thought they were meant to be showing the results but not the process of picking the line positions. Maybe it'll only get shown for offside calls?
Did they show the lines? I must have missed them if so. It looks slightly offside from the freeze frame and using the lines on the pitch.
They don't show the drawing of lines for sure anymore. Not sure they show the lines at all. There is a 5cm "grace" applied in the attackers favour now.
